Hi, I was wondering what is the correct way to build the metal part attached using the Sheet Metal feature. I also attached what I attempted. After the extruded cut, when I "unsupress" the flat pattern feature, the cuts made also disappear. So I was just wondering what is the right order to be doing things
thanks!
Use the unfold feature, add your cat to a "flat" part, then use the fold.
It will add two extra operations in your design tree only for the purpose of designing. and you will see the results on your folded model.
Leszek
