ZEZac Evans23/03/2016
I have a macro that saves the current drawing to pdf in the same file location and the name of the drawing model, I'm new to macros and can't figure out how to have it save today's date to the end of the name (eg. 1234-567-8910 (3-23-16)) in the m-dd-yy format. here's the code I have for it.
Option Explicit
Dim FileName As String
Dim swExportPDFData As SldWorks.ExportPdfData
Set swModel = swApp.ActiveDoc
'Save Drawing
swModel.Save3 0, 0, 0
'Checks to make sure current file is a drawing
If swModel.GetType = swDocDRAWING Then
    'Gets current file name and path
    FileName = swModel.GetPathName
    'strips solidworks extension off name and replaces with pdf
    FileName = Left(FileName, Len(FileName) - 6) & "pdf"
    'message box line used to confirm modified file name
    'MsgBox FileName
    'sets current pdf export options
    Set swExportPDFData = swApp.GetExportFileData(1)
    'saves drawing as pdf
    swModel.Extension.SaveAs FileName, 0, 0, swExportPDFData, 0, 0
Else
    MsgBox "Current File is not a Drawing"
    End
