When I insert a BOM into a drawing, the custom properties
previously defined in the assemby/part file do not show up. The
only way I can make it work is to open each individual
assembly/part file (where the custom property was originally
defined) and then switch back to the drawing window and update the
drawing. As you might expect, this takes ALOT of extra time. Is
this problem caused by something I'm doing wrong, or has the new
version screwed something up?
Has anyone else noticed this problem and figured out a better solution?
Thanks.
Thanks.
What video driver version are you using?
John
