Load block on sheet problem selecting drawing view
Question asked by Kenneth Poppel on Mar 22, 2016
Latest reply on Mar 22, 2016 by Artem Taturevych
I have this program that after choosing the block names from the user form, I pick a point to locate the block on my drawing sheet. This works fine when no drawing views are on the sheet but when the drawing views are loaded on the sheet and you try to pick the location point, the program does not get the point location. It instead selects the drawing view if the point selected is on the component part but loads fine if placed in a hole or off to the side of the component. Can someone help me with ignoring the drawing views when selecting the point on the sheet to for the block location?
Only blocks 3.sldblk and 6.sldblk are attach here for testing and needs to be located in "c\development\blocks\" folder.
Thank you all in advance for your help and comments on this forum, as you will see there are bits and pieces from other samples loaded on this forum to create this swp.
