Hi guys,
Went to draw up my weldment part to send out to the factory and the cut list table is coming up as shown. Any ideas?
Thanks in advance.
Hi guys,
Thanks in advance.
I've also had problems with this, without a consistent cause that I can find. I know that if you use quotation marks (") in the .sldlfp file's Description it will cause the error, but I've run into it in other situations. Someone reported that if they hide the cut list folder, then show it, it would solve the issue (at least temporarily).
The same bug in SW coding discussed in
https://forum.solidworks.com/thread/114282http://
Instead of evaluated value SW returns original equation.
i think i solved this problem. I am working in 2016 so here goes.
I did the "System options>>Document properties>>Weldments then uncheck " rename cut list folders with desc prop value" before starting this:
I hope this helps.
Make sure the profile dimension has those name listed in the cut list. To check, open the weldment profile and check/fix the custom properties in there to make sure that they are linked properly to dimensions.
