I have an assembly for a small machine that I routed all the electrical wires for. After completing the wiring I decided I wanted to adjust some of the ring terminal positions(some were facing up and should have been facing down). The ring terminals have a mate reference to the hole edge. When first bringing them into the assembly I can rotate them any direction I want. Once a wire route has been completed they are locked in place even though they are not fully defined. Is this correct functionality or should they work like a clip that can move around and the wire updates with it?
