i wanted to hide only a particular portion of the surface. so make a sketch, used split line command , selected projection and made the sketch on the surface . now i right clicked the portion to be hidden and selected hide . but the whole surface body gets hidden . how do i fix this ?
Use the "SPLIT" feature to cut the surface body into two surfaces.
than you can your method the hide each surface body individually.
Leszek
