What do you have to do in order to change the material in a weldment cutlist in 2014. I can change the material of the whole part using the Material tab in the feature tree. But when I go to the cutlist it still shows the original material. If I try to change it using the cut list properties, it will change in the tabs until I hit the OK to close out the cut list properties. Then it shows the original material again in the cut list on the drawing. I tried changing the material in the Properties summary in the cut list but that does the exact same thing. It won't even let me delete out the material line in the cut list property & reenter it. Real PITFA & shouldn't be this difficult to change materials.
Did you applied material to the bodies?
