Re: Unintuitive failure: Sliding bracket stuck when wheel turned
J. Mather Mar 20, 2016 3:53 PM (in response to Eg Gloo)I don't have 2016 to check - but do you have logical clearance between the red pin and the slot in the green part?
5mm Pin will not fit in a 5mm Slot. We cannot manufacture perfect parts.-
Eg Gloo Mar 20, 2016 3:59 PM (in response to J. Mather)-
J. Mather Mar 20, 2016 5:13 PM (in response to Eg Gloo)Again, I can't open your assembly - but my next thought is to use a Point-Plane assembly constraint for a more robust solution in place of whatever you did use.
Eg Gloo Mar 21, 2016 9:42 AM (in response to J. Mather)-
J. Mather Mar 24, 2016 8:04 AM (in response to Eg Gloo)Eg Gloo wrote:
I wish there was a way to convert it make it backward-compatible.
Simply Save as STEP and attach here.
It is forward compatible - so I can provide solution in r2015 that you can examine.
Eg Gloo Mar 24, 2016 9:26 AM (in response to J. Mather)I see. Here's the STEP file (hopefully it's convened correctly).
Thanks a lot!
Eg
Assembly.STEP.zip 21.8 KB
Ned Hutchinson Mar 22, 2016 2:14 AM (in response to Eg Gloo)Seems to rotate fine to me heres a video of it spinnig
not quite sure what your trying to acheive though with the yellow block
also from watching your video i see you like to click move component to move stuff, you can just start dragging with LMB or rotating parts by holding RMB
Assembly.zip 10.1 MB
Eg Gloo Mar 22, 2016 6:27 AM (in response to Ned Hutchinson)Hi Ned,
I'm actually trying to rotate with physical dynamics. That is, to allow the bracket to move the block. I think you're rotating without physical dynamics.
Cheers
