Good Morning
I need your support,
I have an assembly which contains "Sheetmetal”, "Hardware" & "Accessories" components,
and need to create a 3 different BOM table templates linked to each category, one template linked to the custom property sheet metal so only sheet metal parts will appear when using this template and another one for hardware custom property and same for accessories parts, already each part defined with custom property depending on its type (sheetmetal, hardware or accessories)
My question how to link the BOM table template to the custom property?
"Each table template for only one custom property"
I'll try to help. Setting up each template to display selected custom properties will be simple enough, but I don't believe you'll be able to get them to automatically show only certain parts. Someone may be able to write a macro to do it, but I don't know enough about them to say for sure.
If not, I believe you could go ahead and insert each table and sort them using the chosen column, which should move all of the components that don't have that property to the bottom. Then hide those rows.
