I have completely reinstalled Windows and SolidWorks.
Now when I open my own project I have BOM where Toolbox standard parts do not represent an actual Part Number size, please see attached pic.
When I insert the new item from Toolbox (see the last row at the pic) it represented fine and as used to be at other rows.
Please advise what may be wrong, I wish I wold have my sizes back in the BOM?
Check your Toolbox settings and see if you're creating parts or configurations.
It looks like the previous SHCS were created as configuration with the config name used in the BOM DESCRIPTION column.
If you're now creating parts, these you your template settings and if the template is set to use the document name (file name) for the DESCRIPTION column, then this is what's showing up.
With just the image to work with, I think this is what's happening: you're creating Toolbox parts instead of configurations.
Cheers,
Kevin
