Hi...
Let me know the function of mass properties in part model.
How to validate the mass of the part as shown in mass properties is correct? and how to optimize the feature tree based on mass value.
With Regards,
D.Prasanna
Hi...
With Regards,
D.Prasanna
Hi Prasanna,
To validate the mass of the part as shown in mass properties just create a simple block say cube, assign material > Check Mass.
Then manually calculate mass of using below formula:
Mass = Density X Volume
If its correct for simple cube then it will correct for all parts .
I didn't get you on "how to optimize the feature tree based on mass value."
Can you please explain little bit more, what exactly you want to do?
Amit
Hi Presanna
if you want to optimize your design you can use
2015 SOLIDWORKS Help - Design Studies in SOLIDWORKS
Leszek
