I am trying to delete the body on the outer edge of the extrusion but I can't select it without selecting the entire extrude. I've tried delete face but it doesn't fill in properly. Can someone suggest a way for me to separate the back and front side from of the extrude cut so that I can then delete it flush up to the rounded feature.Also, I've tried to indent it but I can never complete the command because I can't select a tool body region... any thoughts on why that is? Thanks
Hello Teresa,
have you tried using the SPLIT tool command to cut by surface extrusion, followed by delete/keep body?
Alen
