Batch print of drawings in a specific state Issue
Question asked by Daniel Egebjerg on Mar 17, 2016
Latest reply on Mar 30, 2016 by Daniel Egebjerg
Hi Boys and Girls....
I´ve been trying to make a print task, that only print files in the Workflow state "produktion" but i cannot seem to get it to work... Before i added the state part of the script it worked ( text marked in RED), but printed all referenced files, which i wanted to counter (Our production people, does not need a drawing of a purchased item, and i am to lazy to sort a stack of drawings:))
Any ideas how to solve the problem??
(Please note that i am fairly new in making scripts...)
//Daniel
Dim swApp As Object
Dim swExtension As SldWorks.ModelDocExtension
Dim swPageSetup As SldWorks.PageSetup
Dim swDocSpecification As SldWorks.DocumentSpecification
Dim FileState As IEdmFile5.CurrentState
Dim errors As Long
Dim warnings As Long
Dim Width As Double
Dim Height As Double
Dim DrwPaperSize As Integer
Dim PrintPaperSize As String
Dim A0PrintSize As String
Dim A0ScaleToFit As String
Dim A0Printer As String
Dim A1PrintSize As String
Dim A1ScaleToFit As String
Dim A1Printer As String
Dim A2PrintSize As String
Dim A2ScaleToFit As String
Dim A2Printer As String
Dim A3PrintSize As String
Dim A3ScaleToFit As String
Dim A3Printer As String
Dim A4PrintSize As String
Dim A4ScaleToFit As String
Dim A4Printer As String
Dim OtherPrintSize As String
Dim OtherScaleToFit As String
Dim OtherPrinter As String
Dim FileWorkFlowStateName As String
Dim ExcludeSheet As String
Function PathAppend(path, more) As String
    If Not Right(path, 1) = "\" Then
        path = path & "\"
    If Left(more, 1) = "\" Then
        more = Mid(more, 2)
    PathAppend = path & more
End Function
Sub Log(message)
    ' Determine error log output path
    errorLogFolder = "[ErrorLogPath]"
    ' Trim \ from the start
    If Left(errorLogFolder, 1) = "\" Then
        errorLogFolder = Mid(errorLogFolder, 2)
    ' Build full root
    If PathIsRelative( errorLogFolder ) = 1 Then
        errorLogPath = PathAppend("<VaultPath>", errorLogFolder)
    Else
        errorLogPath = errorLogFolder
    ' Create directory if not exists
    SHCreateDirectoryEx ByVal 0&, errorLogPath, ByVal 0&
    errorLogPath = PathAppend(errorLogPath, "<TaskInstanceGuid>.log")
    ' Write error to output file
    Open errorLogPath For Append As #1
    Print #1, message
    Close #1
Function GetPrinter(paperSize)
    Select Case paperSize
        Case 11
  SheetPrinter = A0Printer
        Case 10
            SheetPrinter = A1Printer
        Case 9
            SheetPrinter = A2Printer
        Case 8
            SheetPrinter = A3Printer
        Case 6
            SheetPrinter = A4Printer
        Case 7
  Case Else
  SheetPrinter = OtherPrinter
  End Select
   GetPrinter = SheetPrinter
  End Function
  Function GetPrintPaperSize(paperSize)
        Case 11
  ConvPaperSize = A0PrintSize
        Case 10
            ConvPaperSize = A1PrintSize
        Case 9
            ConvPaperSize = A2PrintSize
        Case 8
            ConvPaperSize = A3PrintSize
        Case 6
            ConvPaperSize = A4PrintSize
        Case 7
  Case Else
  ConvPaperSize = OtherPrintSize
  End Select
   GetPrintPaperSize = ConvPaperSize
  End Function
Function GetPaperSize(NewPaperSize)
    Select Case NewPaperSize
        Case "A0"
            paperSizeNum = 256 + 4 'DMPAPER_A0  DMPAPER_USER+4
        Case A1
            paperSizeNum = 256 + 5 'DMPAPER_A1  DMPAPER_USER+5
        Case "A2"
            paperSizeNum = 66 'DMPAPER_A2
        Case "A3"
            paperSizeNum = 8 'DMPAPER_A3
        Case "A4"
            paperSizeNum = 9 'DMPAPER_A4
        Case Else
    End Select
    GetPaperSize = paperSizeNum
End Function
Function GetPaperOrietation(paperSize) ' 1 = Portrait 2 = Landscape
        Case 11
            paperorientation = 2 'PAPER_A0
        Case 10
            paperorientation = 2 'PAPER_A1
        Case 9
            paperorientation = 2 'PAPER_A2
        Case 8
            paperorientation = 2 'PAPER_A3
        Case 6
            paperorientation = 2 'PAPER_A4L
        Case 7
            paperorientation = 1 'PAPER_A4P
        Case Else
    End Select
    GetPaperOrietation = paperorientation
End Function
Function GetPrintScale(paperSize) ' 1= Portrait = Landscape
        Case 11
            PrintScaleToFit = A0ScaleToFit 'PAPER_A0
        Case 10
            PrintScaleToFit = A1ScaleToFit 'PAPER_A1
        Case 9
            PrintScaleToFit = A2ScaleToFit 'PAPER_A2
        Case 8
            PrintScaleToFit = A3ScaleToFit 'PAPER_A3
        Case 6
            PrintScaleToFit = A4ScaleToFit 'PAPER_A4P
        Case 7
            PrintScaleToFit = A4ScaleToFit 'PAPER_A4L
        Case Else
            PrintScaleToFit = OtherScaleToFit 'PAPER_A4
    End Select
    GetPrintScale = PrintScaleToFit
End Function
A0PrintSize = "A0"
A0ScaleToFit = False ' True
A0Printer = "\\sbs2011\HP Designjet T770 44in HPGL2"
A1PrintSize = "A1"
A1ScaleToFit = False ' True
A1Printer = "\\sbs2011\HP Designjet T770 44in HPGL2"
A2PrintSize = "A2"
A2ScaleToFit = False ' True
A2Printer = "\\sbs2011\HP Designjet T770 44in HPGL2"
A3PrintSize = "A3"
A3ScaleToFit = False 'True False
A3Printer = "\\sbs2011\Hvid Papir G36C-1 på sbs2011 "
A4PrintSize = "A4"
A4ScaleToFit = True ' False
A4Printer = "\\sbs2011\Hvid Papir G36C-1 på sbs2011"
OtherPrintSize = "A4"
OtherScaleToFit = True ' False
OtherPrinter = "\\sbs2011\Hvid Papir G36C-1 på sbs2011"
ExcludeSheet = "dxf"
FileWorkFlowStateName = "Produktion"
    On Error GoTo Fail:
    Dim docFileName As String
    Dim docCfgOrSheet As String
    Dim sNumCopies As String
    docFileName = "<Filepath>"
    docCfgOrSheet = "<SelCfgOrSheet>"
    sNumCopies = "[__printer_copycount]"
    Dim iNumCopies As Integer
    iNumCopies = 1
    If (Len(sNumCopies) > 0) Then
        iNumCopies = CInt(sNumCopies)
    ' Get SW interface object
    swApp.Visible = True
  ' Determine type of SolidWorks file based on file extension and the files Workflow state
    If LCase(Right(docFileName, 7)) = ".slddrw" Or LCase(Right(docFileName, 4)) = ".drw" And Filestate = FileWorkFlowStateName Then
  docType = swDocDRAWING
    Else
        docType = swDocNONE
    ' Open document
    If docType = swDocNONE Then
        Set swModel = swApp.LoadFile4(docFileName, "", Nothing, errors)
    Else
        Set swDocSpecification = swApp.GetOpenDocSpec(docFileName)
        swDocSpecification.DocumentType = docType
        swDocSpecification.ReadOnly = True
        swDocSpecification.Silent = True
        swDocSpecification.ConfigurationName = ""
        swDocSpecification.DisplayState = ""
        Set swModel = swApp.OpenDoc7(swDocSpecification)
        errors = swDocSpecification.Error
        'Set swModel = swApp.OpenDoc6(docFileName, docType, swOpenDocOptions_Silent Or swOpenDocOptions_ReadOnly, "", errors, warnings)
    ' Load failed?
    If swModel Is Nothing Then
        Log "Method call ModelDoc2::OpenDoc6 for document '" & docFileName & "' failed. Error code " & errors & " returned."
        Exit Sub
    Set swPageSetup = swModel.PageSetup
    swPageSetup.Scale2 = 100
    ' Margins/Headers
    If [__printer_margintype] = 0 Then
        swApp.SetUserPreferenceToggle swPageSetupPrinterUsePrinterMargin, True
    Else
        swApp.SetUserPreferenceToggle swPageSetupPrinterUsePrinterMargin, False
        ' Convert m => mm
        swApp.SetUserPreferenceDoubleValue swPageSetupPrinterTopMargin, [__printer_margintop] / 1000
        swApp.SetUserPreferenceDoubleValue swPageSetupPrinterBottomMargin, [__printer_marginbottom] / 1000
        swApp.SetUserPreferenceDoubleValue swPageSetupPrinterLeftMargin, [__printer_marginleft] / 1000
        swApp.SetUserPreferenceDoubleValue swPageSetupPrinterRightMargin, [__printer_marginright] / 1000
    If [__printer_headertype] = 2 Then
        swPageSetup.SetHeader "[__printer_headerleft]", "[__printer_headercenter]", "[__printer_headerright]"
    If [__printer_footertype] = 2 Then
        swPageSetup.SetFooter "[__printer_footerleft]", "[__printer_footercenter]", "[__printer_footerright]"
    Set swExtension = swModel.Extension
    ' Clear error messages
    Dim vMsgs As Variant
    Dim vMsgIDs As Variant
    Dim vMsgTypes As Variant
    swApp.GetErrorMessages vMsgs, vMsgIDs, vMsgTypes
    vMsgs = Empty
    Dim vPrintSheets As Variant
    'Print one sheet at at a time.
    If docType = swDocDRAWING Then
        Dim vSheetNames As Variant
        Dim nPrintSheets(0) As Long
        Dim swSheet As SldWorks.Sheet
  Set swDraw = swModel
        vSheetNames = swDraw.GetSheetNames
        For i = 0 To UBound(vSheetNames)
             If LCase(vSheetNames(i)) = LCase(docCfgOrSheet) Then
  If LCase(vSheetNames(i)) <> LCase(ExcludeSheet) Then
  ' MsgBox "  SheetName[" & i & "] = " & vSheetNames(i)
  DrwPaperSize = swDraw.Sheet(vSheetNames(i)).GetSize(Width, Height)
  'set the printer
  printer = GetPrinter(DrwPaperSize)
  swModel.printer = printer
  PrintPaperSize = GetPrintPaperSize(DrwPaperSize)
  swPageSetup.PrinterPaperSize = GetPaperSize(PrintPaperSize)
  swPageSetup.Orientation = GetPaperOrietation(DrwPaperSize)
  swPageSetup.ScaleToFit = GetPrintScale(DrwPaperSize)
  'msgbox swPageSetup.Scale2 & " - " & swPageSetup.ScaleToFit & " - " & swPageSetup.PrinterPaperSize & " - " & swModel.printer
  ' Print sheet
  nPrintSheets(0) = 0
  nPrintSheets(0) = i + 1
  vPrintSheets = nPrintSheets
  swExtension.PrintOut2 vPrintSheets, iNumCopies, False, printer, ""
  Else
  Else
        Next i
    ' Check for errors
    If Not IsEmpty(vMsgs) Then
        msg = "Could not print file '" & docFileName & "'. The following errors occured: " & vbCrLf
        For i = 0 To UBound(vMsgs)
            msg = msg & vMsgs(i) & vbCrLf
        Next i
        Log msg
    ' Close document
    swApp.QuitDoc swModel.GetTitle
    Exit Sub
Fail:
    Log "Error while printing file '" & docFileName & "': " & vbCrLf & _
        "An unexpected error occurred while executing the generated script. Script syntax error?" & vbCrLf & _
        "Error number: " & Err.Number & vbCrLf & _
        "Error description: '" & Err.Description & "'" & vbCrLf
