I have a file that wont check in. I get a message that the file isn't checked out by me. Every other file in the assembly checks in fine except this one. There is also no "state" specified for the file.
Hi Mark, can you run a search for the file, and see if it is checked out by another user? If it is, you will not be allowed to check it in, EPDM only allows you to check in files, that are checked out by you. Unless you are the Admin user, in which case you can check in other users checked out files.
Kind regards,
Prasad Bhonsule
