6 Replies Latest reply on Mar 23, 2016 4:42 PM by Dave Paul
    Can a "macro feature" be a constructed note?
    Dave Paul
      Is it possible for a "macro feature" to be a note that has calculated and constructed text?
      Dave
        • Re: Can a "macro feature" be a constructed note?
          Artem Taturevych
          Macro feature cannot behave as the note (you can have dimension with macro feature but not note). What you can do however is to create/update notes from within the regenerate method of your feature. You may associate your note either through macro feature selection or persist id stored in macro feature parameters.
              Dave Paul
              Thank you for your ideas.  Let me give these a try.
                Dave Paul
                OK, the persistent ID's seem to be the direction that will work the best.  Thank you for that idea.
                I am needing some help with re-selecting the objects with the persist id's.  I have collected the ID's, saved them to a file, read the ID's from the file, and I'm having an issue adding the objects to a selection set.
                  swModel.ClearSelection2 True
                  intIndex = 1
                  Do While Not EOF(1)    ' Loop until end of file.
                    ReDim Preserve strFeatureData(intIndex - 1) As String
                    Input #intFileNumber, GetPersistID
                    strFeatureData(intIndex - 1) = GetPersistID
                    intIndex = intIndex + 1
                  Loop
                  Close #intFileNumber
                  ReDim swObj(UBound(strFeatureData)) As Object
                  For i = 0 To UBound(strFeatureData)
                    strIDData = Split(strFeatureData(i), "|")
                    Set swObj(i) = GetObjectFromString(swApp, swModel, strIDData(1))
                  Next i
                The swObj(i) is set to the correct object, but I do not know how to save that object and create a selection set that includes all the other objects.
                    Artem Taturevych
                    I missed your question, sorry. Are you asking of how to select those objects or how to store them in a file rather than external file? If the later one you can use a 3rd party storage or macro feature parameters to store the data internally in the SolidWorks file.
                        Dave Paul
                        Sorry for the confusion.  I have read the persist id's back from a file.  Using the persist id's, how do I select the objects and add them to a selection set?  I could have one id and I could have a bunch, so I need a loop.
                            Dave Paul
                            I got it.  Used the AddSelectionListObject method.
                                Set swSelObj = Nothing
                                Set swSelObj = GetObjectFromString(swApp, swModel, strIDData(1))
                                If Not swSelObj Is Nothing Then
                                  If strIDData(0) = swSelBODYFEATURES Then
                                    Set swFeat = swSelObj
                                    swSelMgr.AddSelectionListObject swFeat, swSelMgr
                                  If strIDData(0) = swSelNOTES Then
                                    Set swNote = swSelObj
                                    swSelMgr.AddSelectionListObject swNote, swSelMgr
                              Next i
