How to use swCustProp.Add ?
Question asked by Don Michaels on Mar 15, 2016
Latest reply on Mar 16, 2016 by Don Michaels
I am trying to use macros to get, add, and delete custom properties. The code I have does not add a custom property. There is no error, it just doesn't add the custom property. The 'get' code does work.
Here is the macro code:
Option Explicit
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
Dim swSelMgr            As SldWorks.SelectionMgr
Dim swFeat              As SldWorks.Feature
Dim swCustPropMgr       As SldWorks.CustomPropertyManager
Dim nRetVal             As Long
Dim vNameArr            As Variant
Dim vName               As Variant
Dim bRet                As Boolean
Dim TestPropVar        As String
Dim TestFieldName      As String
Dim TestFieldValue     As String
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
If swModel.GetType = swDocPART Then
    Set swCustProp = swModelDocExt.CustomPropertyManager("")
    'Get a Custom Property value
    bool = swCustProp.Get4("Part_Number", False, val, valout) 'This WORKS
     'Add a Custom Property
    TestPropVar = "TestVar"
    TestFieldName = "Test_Cust_Prop"
    TestFieldValue = "TestIT"
    bool = swCustProp.Add(TestFieldName, TestPropVar, TestFieldValue) 'This DOES NOT WORK
End If 'is part
I appreciate any suggestions.
Don Michaels
Belcan Engineering, Solon Ohio
