I need help please! I have everything I need to load but I
get anerror as I begin: "an appropriate .dll is not available.
Cananyone please get me going again? I have removed V6 and
allremnants so I am dead in the water at home..........
jiggle the mouse!
OK, seriously, missing DLL's usually mean bad installer image. When
you try to install 07 on your home machine are you using the CD sw
shipped to your componay or are you using a CD you burned or an FTP
transfer or download or something?
here's the big reason I ask: with Solidworks 2007, all of the
isntallation files won't fit on a single 4.3Gb DVD and if you leave
it to burning software, it will drop some files. In that case, your
best bet is to remove some language packs your not using: French
and Italian in my case.
I had the same problem - I could not install SW2007 SP4.0 on myhome PC but I had no problems in installing SW2007 SP3.1
Try to install SW2007 SP3.1 or lower - it should work then.
Lukasz
Dan
OK, seriously, missing DLL's usually mean bad installer image. When you try to install 07 on your home machine are you using the CD sw shipped to your componay or are you using a CD you burned or an FTP transfer or download or something?
here's the big reason I ask: with Solidworks 2007, all of the isntallation files won't fit on a single 4.3Gb DVD and if you leave it to burning software, it will drop some files. In that case, your best bet is to remove some language packs your not using: French and Italian in my case.
start with that and lemme' know.
John
'07 and later will not even install on Win2k... Or anything under XP
