I was reading through UI stuff today (we wereupgraded to 2008 over the weekend) and then I came across this.Trying to delete a sketch and then a feature has two different hotkeys for the same things. Why? In the sketch mode you have to use"L" and in the feature mode you have to use "D". Can anyonedescribe the logic behind this? Thanks, Dale
I know you can't change them, and I'm not even sure if SW can change them - they are a Windows function. (Maybe they can, I really don't know.)
So my advice is always to see what your system has that is consistent, and if you find one that does what you want of it, by all means use it. But keep in mind that you may go to your neighbor's machine and it could be different based on what menu items he as showing.
WT
