I am still using SW 2012 x64 and I just built a new machine. I moved over my SolidWorks to and started working on a part (which is a weldment). I was using feet and inches for my units and everything was fine on the old machine. I used copy user settings and opened the part. Now I can't modify dimensions using feet and inches (example: I insert 10'4.75" and the dimension will not update.) I go back to the old machine, and the modified dimension updates perfectly. What setting am I missing??? I attached my problem log.
Found the solution. Follow the link below to fix a this problem. This issue can occur in SolidWorks 2011 - 2015 and 2016 beta. Its a Windows Updated that causes this issue.
SOLIDWORKS
