Tying Custom Properties tab and Configuration Specific Properties tab together?
Question asked by Cory Phelps on Mar 11, 2016
Latest reply on Mar 22, 2016 by Cory Phelps
Okay, hopefully I can explain this well enough. We are a small company and we are moving over to PDM for the first time. I set several custom properties as mandatory when checking a file into the vault. The problem we're running into is that when we fill in the custom properties in the task pane tab it will only fill in either the custom properties tab field or the configuration specific field depending on how we have the task pane set. This causes PDM to reject the check-in of the file, unless we go in and fill in the same information on the other tab (Custom Properties/Configuration Specific). So is there any way to tie these two together so we can just use the task pane tab to enter the info, and not have to enter the same stuff twice?
Hopefully this made sense...
Thanks in advance for any help!
