2 Replies Latest reply on Mar 10, 2016 7:58 AM by Erik Söderby
    Change reference entities for RefPlane (API)
    Erik Söderby
      Hi! I want to replace the reference entities for a RefPlane(Plane1), from Axis1 and Point1 to Axis2 and Point2. I get no errors, but nothing happens. Note that this works if the entities happen to be splines or other sketch segments, but not when I'm working with reference points/axises as entities. Does anyone have an idea?
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Dim ReplacementEntity1 As SldWorks.Feature
      Dim ReplacementEntity2 As SldWorks.Feature
      Dim FeatureToAdjust As SldWorks.Feature
      Dim swRefPlane As SldWorks.RefPlane
      Dim swRefPlaneData As IRefPlaneFeatureData
      Dim FeatMgr As SldWorks.FeatureManager
      Dim SelArr As Variant
      Dim Selection As Variant
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      Set swSelMgr = Part.SelectionManager
      Set FeatMgr = Part.FeatureManager
      '***Setting the two replacement entities:
      boolstatus = Part.Extension.SelectByID2("Axis2", "AXIS", 0, 0, 0, True, 0, Nothing, 0)
      Set ReplacementEntity1 = swSelMgr.GetSelectedObject6(1, -1)
      Part.ClearSelection2 True
      boolstatus = Part.Extension.SelectByID2("Point2", "DATUMPOINT", 0, 0, 0, True, 0, Nothing, 0)
      Set ReplacementEntity2 = swSelMgr.GetSelectedObject6(1, -1)
      '**The plane I want to change reference entities for:
      boolstatus = Part.Extension.SelectByID2("Plane1", "PLANE", 0, 0, 0, True, 0, Nothing, 0
      Set FeatureToAdjust = swSelMgr.GetSelectedObject6(1, -1)
      Set swRefPlaneData = FeatureToAdjust.GetDefinition
      boolstatus = swRefPlaneData.AccessSelections(Part, Nothing)
      '**Set new reference entities for the RefPlane
      SelArr = swRefPlaneData.Selections
      For I = 0 To UBound(SelArr)
      Set Selection = SelArr(I)
      If Selection.GetTypeName2 = "RefAxis" Then
      Set SelArr(I) = ReplacementEntity1
      ElseIf Selection.GetTypeName2 = "RefPoint" Then
      Set SelArr(I) = ReplacementEntity2
      Next I
      swRefPlaneData.Selections = SelArr
      boolstatus = FeatureToAdjust.ModifyDefinition(swRefPlaneData, Part, Nothing)
      swRefPlaneData.ReleaseSelectionAccess
      Part.EditRebuild3
