I'm creating a model of a sheet of glass that's 200mm in diameter.
One surface is covered with an opaque coating 1 micron thick which is perforated by a hole pattern (consisting of 3 holes) which is repeated across the entire part on a 0.50mm pitch.
That's about 125 000 holes.
What's the most efficient way of producing the hole pattern?
Create another config with those micron feature suppressed. Use real view appearance to show the cut outs.
