EPDM API issues pulling parts for SolidWorks
Question asked by Joe Pickens on Mar 9, 2016
Latest reply on Mar 10, 2016 by Joe Pickens
So I wrote a macro that searches the vault and finds the files and then i use the file locations to insert the files into solidworks. the macro used to work fine but i made a change to do a batch add into the solidworks assembly and now it acts like the API cant reach the file locations and also when i switch it back the macro still acts like it cant find the file locations.
This is the macro I wrote
Sub Open_New_Asm_and_Srt_Search()
'For Solidworks
Dim SWApp           As SldWorks.SldWorks
Dim SWModel         As SldWorks.modelDoc2
Dim SWAsm           As SldWorks.assemblyDoc
Dim SWAddComp       As SldWorks.modelDoc2
Dim SWComp          As Component2
Dim SWAsmEvents     As Class1
'For EPDM
Dim VaultApp        As New EdmVault5
Dim EPDMSearch      As IEdmSearch7
Dim EPDMSearchR     As IEdmSearchResult5
Dim EPDMFile        As IEdmFile10
'General
'Dim SWCompName      As String
Dim TLAsmTemp       As String
Dim SWAsmTitle      As String
Dim SWAsmName       As String
Dim FName           As String
Dim CompName        As String
Dim CompPath(200)      As String
Dim FPath           As String
Dim FType           As String
Dim FDate           As String
Dim VaultID         As String
Dim UserID          As String
Dim Passowrd        As String
Dim OpSeq           As String
Dim count           As Integer
Dim Row             As Integer
Dim i               As Integer
Dim FSize           As Long
Dim Errors          As Long
Dim Warnings        As Long
Dim PrtAsm          As Long
Dim Str             As Variant
Dim CompsForm       As Variant
Dim Comps           As Variant
Dim AddComps        As Variant
Dim boolstat        As Boolean
Dim CompCoordSysNames(1) As String
Dim CompXforms(15)              As String
Dim VCompCoordSysNames As Variant
Dim VCompXforms          As Variant
'Open new session of SolidWorks
    Set SWApp = CreateObject("SldWorks.Application")
'Define assembly template location
    TLAsmTemp = "C:\Users\pickensj\Documents\Templets\JOE'S MO ASSY.asmdot"
'Open new Solidworks Assembly with specified Template
    Set SWModel = SWApp.NewDocument(TLAsmTemp, 0, 0, 0)
'Show Solidworks assembly
    SWModel.Visible = True
'Set up events
    Set SWAsm = SWModel
'Get the title of the assembly document
    SWAsmTitle = SWModel.GetTitle
'Split the title into two strings using the period(.) as the delimiter
    Str = Split(SWAsmTitle, ".")
'Set assemby name for use in mating in module5
    SWAsmName = Str(0)
'Login to EPDM Vault
    VaultApp.LoginAuto "MIG1", 0
'Do a loop search till there is a blank value in column A
    While Sheets("JDE BOM").Range("A6").Offset(i, 0).Value <> ""
    'Use Values that only have the number 1 in column E
        If Sheets("JDE BOM").Range("E6").Offset(i, 0).Value = 1 Then
        'If the statement is true use the value in column "A" as the name of the file
            CompName = Sheets("JDE BOM").Range("A6").Offset(i, 0).Value
            OpSeq = Sheets("JDE BOM").Range("C6").Offset(i, 0).Value
        'Create a search in the EPDM Vault
            Set EPDMSearch = VaultApp.CreateSearch()
            EPDMSearch.FileName = "%" & CompName & "%"
            EPDMSearch.FindFiles = True
            EPDMSearch.FindFolders = False
            EPDMSearch.FindHistoricStates = False
            EPDMSearch.Recursive = True
        'Get the first file in the EPDM Vault
            Set EPDMSearchR = EPDMSearch.GetFirstResult
        If EPDMSearchR Is Nothing Then
            GoTo End_of_Sub
        'Get the File info from EPDM Vault File
            FPath = EPDMSearchR.Path
            FName = EPDMSearchR.Name
            FDate = EPDMSearchR.FileDate
        'Loop through all files in the vault untill...
            While Right(FName, 6) = "SLDPRT" And Right(FName, 6) = "sldprt" And _
                Right(FName, 6) = "SLDASM" And Right(FName, 6) = "sldasm"
            'If there is no matching file in the vault end sub
                On Error GoTo End_of_Sub
            'Goto next file
                Set EPDMSearchR = EPDMSearch.GetNextResult
            Wend
        'End of loop
        'Define file info variables
            CompPath(count) = EPDMSearchR.Path
        'Set variable incrament instance
            count = count + 1
End_of_Sub:
        i = i + 1
    Wend
' Add a rotational diagonal unit matrix (zero rotation) to the transformation matrix
    CompXforms(0) = 1#
    CompXforms(1) = 0#
    CompXforms(2) = 0#
    CompXforms(3) = 0#
    CompXforms(4) = 1#
    CompXforms(5) = 0#
    CompXforms(6) = 0#
    CompXforms(7) = 0#
    CompXforms(8) = 1#
' Add a translation vector to the transformation matrix
    CompXforms(9) = 0#
    CompXforms(10) = 0#
    CompXforms(11) = 0#
' Add a scaling factor to the transform
    CompXforms(12) = 1#
' The last three elements of the transformation matrix are unused
' Register the component's coordinate system name
    CompCoordSysNames(0) = "Coordinate System1"
  ' Add the component to the assembly.
  VCompXforms = CompXforms
  'vcompXforms = Nothing  ' also achieves zero rotation and translation of component
  VCompCoordSysNames = CompCoordSysNames
Comps = CompPath
'Acts like file path is invalid/ works when i set path instance to normal folder and doesn't when pointed to files in the vault
AddComps = SWAsm.AddComponents3(Comps, CompXforms, VCompCoordSysNames)
