I have a model I am working on for a "library part" that will changed based on certain values put in. There are a lot of equations, mainly linking values from external ref. On this part I have a dimension that has a value based off of another ref plus a quarter inch for wall thickness (this wall thickness doesn't really matter, just so long as its not too much more than .25) some of our external ref are in MM or just random inches, like 1.778 for example. so that plus the .25 equals a certain distance, I want that certain distant to round up to the nearest 1/16" if possible... Is there a good way to do this in the equations dialog box? Or at all?
I've attached a part with the equations in the Manage Equation dialog, so I won't overelaborate here, but:
See the attached. I hope it addresses your post.
Cheers,
Kevin
