14 Replies Latest reply on Mar 15, 2016 4:54 PM by Prarthana Bataju
    How to get sketch line information using dimension
    Saugat Kc
      I want to get sketch line information using dimension property. I was successful getting all sketch dimension values as well as sketch line information(start point, end point) separately using their own properties but I want to get a link between these two information for example if I have a dimension information, i should be able to get sketch information on which this dimension has been created. More details is shown in figure:
      Is there any way doing this. I was not able to get any concrete information from API as well.
        • Re: How to get sketch line information using dimension
          幸 柴 田
          I can't find the way to get line length directly too.
          But I think if you can get start point and end point, you can calculate length like below.
          sqrt(( end point x - start point x)^2+(end point y - start point y)^2)
            Artem Taturevych
            Try DisplayDimension::GetAnnotation and then Annotation::GetAttachedEntities3.
            Atem
                Saugat Kc
                I will try and let you know if I can solve my problem with this. Thanx for stopping by
                  Saugat Kc
                  Ya it worked... thanx for your help
                    Saugat Kc
                    Hello Artem,
                    There is a slight mistake on implementing correct dimension annotation. When I select the line segment after getting its entities, it is selecting following line segment rather than itself. for example.
                    When dimension L is selected, it is giving me red circled line as its line segment. Similarly when F is selected, it is giving blue circled as its line segment.
                    My implemented code is as follows:
                    public List<DimensionList> getSunpouData(Feature swFeature)
                                double value = 0.0;
                                DisplayDimension swDisplayDim = swFeature.GetFirstDisplayDimension();
                                List<DimensionList> ListDimension = new List<DimensionList>();
                                while (swDisplayDim != null)
                                    SolidWorks.Interop.sldworks.SketchSegment StartEndSegment = default(SolidWorks.Interop.sldworks.SketchSegment);
                                    Annotation swAnnotation = swDisplayDim.GetAnnotation();
                                    Dimension swDim = swDisplayDim.GetDimension();  //IT GETS CORRECT DIMENSION
                                    object[] annoEntities = swAnnotation.GetAttachedEntities3();
                                    var EntityType = swAnnotation.GetAttachedEntityTypes();
                                    int i = 0;
                                    foreach (object EntityObj in annoEntities)
                                        if (EntityType[i] == 10) // ONLY FOR LINE SEGMENT AS ALL ANNOTATION DOES NOT PROVIDE POINT INFORMATION
                                            StartEndSegment = (SolidWorks.Interop.sldworks.SketchSegment)EntityObj;
                                            StartEndSegment.Select(false);     //SELECT CIRCLED LINE SEGMENT.
                                            SolidWorks.Interop.sldworks.Sketch swSketch = StartEndSegment.GetSketch();
                                            SolidWorks.Interop.sldworks.SketchLine swSketchLine = (SolidWorks.Interop.sldworks.SketchLine)StartEndSegment;
                                            SolidWorks.Interop.sldworks.SketchPoint swSkStartPoint = swSketchLine.GetStartPoint2();   //CIRCLED LINE VERTICES ARE GIVEN
                                            SolidWorks.Interop.sldworks.SketchPoint swSkEndPoint = swSketchLine.GetEndPoint2();      //CIRCLED LINE VERTICES ARE GIVEN
                                        i++;
                                    value = swDim.GetSystemValue2("") * 1000;
                                    string swDimensionName = swDim.Name;
                                    ListDimension.Add(new DimensionList() { DimensionName = swDimensionName, DimensionValue = value});
                                    swDisplayDim = swFeature.GetNextDisplayDimension(swDisplayDim);
                                return ListDimension;
                    What can be my possible mistake ?
