I am wanting to use the property tab to edit the sheet scale. I only have been able to do this using macros. Does anyone know of a better way?
For individual views, section or detail views I use the attached macro written by Leon Wurr which is really quick, however you need a bunch of different ones to go from 1:1 to 1:100 etc...
If you select the front view and change the scale there, it should update your note in the drawing title block...
