6 Replies Latest reply on Mar 4, 2016 3:42 AM by Divyanshu Bhardwaj
    Create userform for inserting notes into drawing sheet
    Divyanshu Bhardwaj
      Hi Everybody,
                     I have never created userform before in solidworks. But need to create one this time, where i want to put all the standard notes along with their description, check boxes and options to select flag.
      1. Suppose there are 15 notes, out of which any number of notes can be placed in sheet.
      2. Check Boxes need to be placed in front of the Note names, once checked only those notes will be inserted.
      3. Flag (Kind of option box), once checked need to insert a triangular flag over a corresponding number of a note.
      And some buttons like continue/ cancel etc.
                     Now, the coding part i can do, but i don't know how to create and associate those controls to the specific codes. Please Suggest a way to proceed. Thank you
          • Re: Create userform for inserting notes into drawing sheet
            Divyanshu Bhardwaj
            Hi Deepak,
                      Thanks for quick reply and working link. But here i am having little problem with the second check-box. As shown below i want something
            like this. There will be 14 more notes (similar to as shown here only one line). But i am having difficulty in associating both the check boxes. The first one inserts a note. While if checked, the second one adds a triangular box over the number. How to make this possible.
            The code i wrote for this is....
            Private Sub Continue_Click()
                Call SL1_Click
            Private Sub Note1_Click()
                If Note1.Value = True Then
                    Set swModel = swApp.ActiveDoc
                    Dim swNote As SldWorks.Note
                    Set swNote = swModel.InsertNote("Part Number Marking Per Find Number SPCX, PROCEDURE X, (But Do Not Serialize).")
                    If Not swNote Is Nothing Then
                       swNote.LockPosition = False
                       swNote.Angle = 0
                       boolstatus = swNote.SetBalloon(9, 0)
                       Set myAnnotation = swNote.GetAnnotation()
                       If Not myAnnotation Is Nothing Then
                          longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
                          boolstatus = myAnnotation.SetPosition(0, 0, 0)
                          Set myTextFormat = swModel.GetUserPreferenceTextFormat(0)
                          myTextFormat.Italic = False
                          myTextFormat.Underline = False
                          myTextFormat.Strikeout = False
                          myTextFormat.Bold = False
                          myTextFormat.Escapement = 0
                          myTextFormat.LineSpacing = 0.001
                          myTextFormat.CharHeight = 0.003175
                          myTextFormat.TypeFaceName = "Century Gothic"
                          myTextFormat.WidthFactor = 1
                          myTextFormat.ObliqueAngle = 0
                          myTextFormat.LineLength = 0
                          myTextFormat.Vertical = False
                          myTextFormat.BackWards = False
                          myTextFormat.UpsideDown = False
                          myTextFormat.CharSpacingFactor = 1
                          boolstatus = myAnnotation.SetTextFormat(0, False, myTextFormat)
            Unload Me
            Exit Sub
            swModel.ClearSelection2 True
            swModel.WindowRedraw
            Private Sub SL1_Click()
                If SL1.Value = True Then
                    Call Note1_Click
                ElseIf SL1.Value = False Then
                    MsgBox "Nothing Checked!!! Exiting Sub..."
                    Exit Sub
                Unload Me
            Note: SL1 is the name for first checkbox while Note1 the second.
