I'm using a design table for my part to generate multiple configuration (8 total). I've got like 8 columns in my design table for each configuration (so 8x8 table). I was under the impression that my file size wouldn't be much higher than that of a single configuration (since I'm using a design table), but that is not the case. There are some features that are simply suppressed between the configurations, but it's mainly design table driven (dimension values).
With all 8 configurations loaded, the file size is around 18mb. If I do a save-as and only one configuration is loaded, it's around 3mb. Is there a way to "unload" the unused configurations? This file size is just too high. Thanks.
Here are some ideas:
http://help.solidworks.com/2015/english/SolidWorks/sldworks/t_Purging_Configuration_Data.htm?id=3e5650144229461cbb26c23e396600f6#Pg0&ProductType=&ProductName=
(in case the link doesn't work, here is the text pasted):
Purging Configuration Data
To reduce the size of files and the time needed to save them, you can purge the cached configuration data of inactive configurations.
Related tasks
Related reference
Purging the Data Manually
You can manually purge the data of inactive configurations.
Purging the Data Automatically
and
http://help.solidworks.com/2015/english/SolidWorks/sldworks/HIDD_SAVE_CONFIGS.htm?id=b593743480374e08b9f4cc3d8f388eaa#Pg0&ProductType=&ProductName=
See if these help you out.
