Hi guys,
When I try to change the state of a document, I got an error "Archive Server connection socket could not send data".
Can anyone advise what is the problem?
Thanks in advance.
James
Hi guys,
Thanks in advance.
James
Check the log in the administration tool. Sometimes that will shed some light on what's happening. I recently had a client with this and it was the transaction log file was full because the tempdb was full. IT reallocated space on their VM and it stopped the error.
Hope this helps,
Tim CEPA
equivaQ
Hi Tim, thank you fo your reply. Unfortutantly that's not my case. The log on the archive server report tons of E_FVC_UNKNOWN_ERROR and E_FVC_SOCKET_CANT_RECEIVE errors that seems affect just a small subset of pc (about 5 over 24).
I would need an advice over some tools tobe used to investigate this kind of issue. I don't know if wireshark could be the right one or if it's more convinient proceed in a different way.
This is an example:
Date: 2016-07-29 16:37:18.000
Module:
Function: Connection::mhWrite
Code: E_FVC_UNKNOWN_ERROR
Code Description: Errore sconosciuto sul server archivio.
No data socket found.
Operation type: Op_PutFile
GUID: 74c5d83e-69f4-4058-8b3c-058ea6582a61
File ID: 0x28e3
Vault: 0000003AB6E175F8
Revision: 2
Fix mismatch: Yes
Connected to: 172.16.65.206:50054
Local file path: E:\EPDM_ARCHIVIO\CUSTOMER\3\000028e3
Module:
Code: E_FVC_SOCKET_CANT_RECEIVE
Code Description: Il socket della connessione non ha ricevuto i dati.
File ID: 0x28e3
Revision: 2
Fix mismatch: Yes
Besr regards,
Davide
Same here, does anyone found a solution o a root cause to investigate?
Thank you in advance
Davide
