I am setting up a Floworks project and need to check what
themesh looks like. What is the best way of doing this? How should
youknow how fine a mesh to use? Any help would be
appreciated.Thanks,
Star off by selecting "show basic mesh" - this shows what
your initial mesh settings create (# of cells in x,y,z) - run the
simulation, but only generate the mesh (unselect run solver) - load
the results and right click mesh, 3d view and select what you want
- normally show all fluid cells is best, it creates the full 3d
cell structure showing where there are larger (less precise) cells
and where the detail suggests smaller cells would be better - as
for how fine a mesh, select the finest your computer can handle
(more cells require more power) and temper it with how long you're
willing to wait for an answer
Just like that. Thanks Chris
