I have a BOM that was working fine. But after making some
changesto the assembly all of the quantities changed to "-" inthe
BOM and three custom properties changed to "X" on sixparts that
where in consecutive rolls. If I insert a new BOM thequantities are
correct but the custom properties are still"x"? I checked the parts
themselves and the customproperties are correct in the parts.
Can anyone give me insight as to how to fix this problem? Pleasehelp I'm trying to get a project out!
Rick
Rick
But the issue with the quantity column changing to "-"still persists. I have seen it before and it can be fixed byinserting a new BOM but that a pain! Because I have to thenreorder all item which is cumbersome to say the least in SW. Now Ihave an issue where I can't insert blank lines in the BOM. Thatoption just disappears from the RMB menu. I have also seen thishappen before. In this drawing I could insert one row,then when I went to insert the next row the option was justgone from the RMB???? I seems just like SW works good up to acertain size assembly then once you reach a certain number of partsSW just can't handle it and progress is plagued with all sortsof issues like these when trying to complete a drawing? I havespent days before trying to complete drawings that should havetaking hours because of these issues. The assembly I'm working withnow has.
611 components
542 parts
133 unique parts
68 subs
34 unique subs
Not even that large compared to some of the assembly I workwith!!!!
