I am assuming all of you have contacted your VAR with this
issue. This sounds pretty serious and needs to go through the VAR's
so it gets back to SolidWorks.
Can one of you clarify this issue a little bit. Did the
problemoccur after you ran the update on PDMWorks? Did you
customproperties file get lost in the upgrade or something?
Thanks!
FYI - This was for 2008 PDMWE. The Service Request is in the
system. The solidworks file custom properties was reset to default.
The variables in the part card within PDMWE were fine. We re-added
the custom property fields in the part file within solidworks and
re-checked in the file. The data re-appeared in the part
card.
We have 1000s of parts. Any solution to fix this issue would be greatly appreciated!
Cheers,
FYI - This was for 2008 PDMWE. The Service Request is in the system. The solidworks file custom properties was reset to default. The variables in the part card within PDMWE were fine. We re-added the custom property fields in the part file within solidworks and re-checked in the file. The data re-appeared in the part card.
