New to macro building so trying to start small while I get my head around it all!
I would like to create an offset line within a sketch from a selected face and link the dimension to a variable.
setup:
Open all new parts using a standard part and assembly template to set up the common global variables I want to use
Global variables created by template - "rebate"
Sketch on the target surface open with one face selected
Run macro:
Macro uses the edges of the pre-selected face to act as the input edges for an inward offset
The offset is applied and then dimension changed to the global variables "rebate"
The selected face and edges are deselected
End
I have had a bit of a play around with codes I have found but can't work out how to link the created offset dimension to a global variables. Any one help me understand how to select the created dimension offset command and linking my variable.
Krishna
Dim swApp As Object
Dim Part As Object
Dim ModDoc As ModelDoc2
Dim boolstatus As Boolean
Set ModDoc = swApp.ActiveDoc
Dim SelMgr As SelectionMgr
Dim EdgeCount As Integer
Dim Edges() As Edge
Dim SelFace As Face2
Dim SelData As SelectData
Dim SelectedCount As Integer
If ModDoc Is Nothing Then
Else
Set SelMgr = ModDoc.SelectionManager
If SelMgr.GetSelectedObjectCount2(-1) = 1 Then
Select Case SelMgr.GetSelectedObjectType3(1, -1)
Case swSelectType_e.swSelFACES
Set SelFace = SelMgr.GetSelectedObject6(1, -1)
If SelFace Is Nothing Then
Else
EdgeCount = SelFace.GetEdgeCount
Edges = SelFace.GetEdges
Set SelData = SelMgr.CreateSelectData
ModDoc.ClearSelection2 (True) ' This Clears the selected Face
SelectedCount = SelMgr.AddSelectionListObjects(Edges, SelData)
swApp.SendMsgToUser2 "There Were " & SelectedCount & " Edges Selected", _
swMessageBoxIcon_e.swMbInformation, swMessageBoxBtn_e.swMbOk
Set Part = swApp.ActiveDoc
boolstatus = Part.SketchOffsetEntities2(-0.00001, False, False)
'' connect "rebate" to the offset above
Part.ClearSelection2 True
End Select
