Hi everybody
Is there any way to link hole wizard with cosmetic thread. I want to change the configuration of bolt , then nut hole wizard be changed automatically .
I am welcome with any comment.
Hi everybody
I think that you can use Smar Component - 2014 SOLIDWORKS Help - Smart Components
Smart Fasteners and Smart Components in SolidWorks [Webcast] - YouTube
Hi Tateos
Thanks for your reply . Let me explain more . I have a bolt with specific thread( for example M8x1) that is cosmetic , and it be joined with appropriate nut ( the nut have hole wizard M8x1) . i make many configuration of bolt (pg , ansi inch , ,metric ) and want to when i change the configuration of bolt (with a cosmetic thread ) the hole wizard be change automatically . Is there any way?
OK,
So you have to use design table and to configure the hole wizard.
This will help you - 2016 SOLIDWORKS Help - Hole Sizes in Configurations
Tanks
You make 4 configurations . But I dont want to make configuration , I want to relate the hole wizard configuration of nut with bolt .
I think that the cosmetic thread is an imaginary and dont have any usage except for show in drawing .
I search for link the cosmetic thread with hole wizard , (i mean when i change the configuration of bolt by use of pop up ,the hole wizard future be change automatically , but it seams there isnt any way .
Assume I have a bolt part with 100 configuration of different cosmetic thread , now i have to create 100 sub assembly configuration of bolt and (as a result ) i have to try 100 time to change the configuration of hole wizard , it is boring .
Hi every body
94 view and no reply . ...!!!
