Hi!
Im trying to register my SW Visualization and its saying AN ERROR OCCURED VALIDATING THE SOLIDWORKS SERIAL NUMBER. Pleace contact support.
I have solidworks professional license.
Need help
Hi!
Need help
Hi Alen!
I have it thats for sure!! Week ago when i tried to download visualize from download i had all options locked and i send a message about that and they fix it. So there was some issues with my subscription but now its supposed to be OK...
Hello Igor,
Please contact your local VAR, and ask them to check if your assets have been updated by SOLIDWORKS on the VAR portal, there could still be some lingering issues with your serial number hence why it is blocking you from using it to activate your version of Visualize.
Hope this helps,
Alen
Alright, sorry I could not be of more help, try contacting Brian Hillner, he should be able to assist you more with this issue.
Good Luck!
Alen
Hello Igor,
If you are getting that error it most likely has to do with an expired subscription. To be able to activate your version of SOLIDWORKS Visualize you need to be on active subscription for this year, which then permits you to activate your Visualize software.
Hope this helps,
Alen
