Is there a simple approach to set the default inside radius when creating an edge flange. The issue is having to change / enter the "Inner default Radius" every time when creating a flange especially within the same part, material and thickness. This has led to may incorrectly programmed flanges. From within the "Sheet Metal" tab, I select the "Edge Flange" icon - "Flange Parameters" - "Inner default Radius". Thanks for the help!
Hi Wally
You can change the inner radius in the sheet metal properties icon and save that as a template . (As a trick)
