Can someone help me create this. I've tried multiple times, but have failed miserably. I'm just not getting anything that looks good enough to use, because I'd also like to print it. Help would be appreciated. Thanks.
...default planes only,.. side plane for the master (side) profile and the front for the front profile.. and you see the front profile refers to the side (master.. which means, it generally controls other sketches downstream).
Can you attach what you consider to be your "best" attempt?
