Hello
I faced a problem adding another pipe to library.
Adding through add component gives me msg "start solidworks first and open the part" (solid is open and part as well)
Simply making another part file in same directory not working. manager simply dont see it.
after hours of "playing" with different options i found that routing.db file simply not updating. deleting it gives an error.
Something is wrong with the manager. also i cannot add any pipe component. getting same error msg "start solidworks first and open the part"
Please help.
Thanks.
Alexey,
I have been having issues with routing.db for years now.
The only advice I can give you is to contact your VAR and see if they can provide you with an answer.
If they can't, and I don't expect them to be able to, then they'll have to contact Solidworks themselves. If enough people do that then perhaps one day someoneat Solidworks will actually take the time to see what it is that is wrong or what people or doing wrong so that it doesn't seem to work as people expect it.
