DKDave Krum24/02/2016
Good morning,
Not sure if I keyed in the correct wording when I did a quick search for this so I'm asking it here since I got no hits.  Simple question but not sure if its possible with SW.  If I hover the mouse on top of any given dimension in a drawing, it would be really nice to see the entity where it is referencing highlight as well.  I used other software in the past that did just this.  Usually its a no brainer where the reference line is obvious, but if there are alot of lines and you can't remember if you pulled from the right one, it would be alot easier to simply highlight the dimension and have the referenced line highlight along with it.  At least on my copy (I may not have a setting turned on for this), it does not highlight.  See below screenshot for an example.  Thanks in advance.
