Dear Sir,
I had published the Composer file in PDF. When I opened that PDF file it's showing the enterer Composer player window. There is any possible to shows only the animation playing window. I have attached some image files for the reference.
Thank You,
Regards,
KALIAPPAN
Far as I am aware there is no default way to block the views from coming into the player like with the tree and other options. The user can turn them off but they would still be able to be viewed if wanted. The only option I know of would be to create a separate file with no views then you would obviously not see them. Someone with some more API experience than myself may be able to find you a way to do it.
Cheers,
Derek
