How can I create a draft on this non-planar surface:
View from front:
View from side:
Hi Edwin:
You might to use Surface feature to accomplish this.
If you upload a sample file here, I believe many forum user will give more practical ideas.
Regards
OK I don't have the exact file but here's the same problem:
The file is attached.
The file attached is not the same as your screen capture. Not sure this is what you want to achieve.
You still can Draft surface if your want.
That seems OK for that file but here's the actual file that I'm trying to draft..why then can't I do it on this:
Edwin,.. I'd rollback and fix the 2.13 offset and add the draft before the shell,..
It sure worked but I'm having difficulty trying to select the edges for the Surface-Untrim1.
after I select the 2nd edge, SW tells me that it cannot be untrimmed.
I don't know what your attempting but... Surface-Untrim1 is extending the "edges" of the face(s) shown so they extend beyond the Surface arc offset 2.13.
Hi Edwin:
Regards
