Was wondering why display/delete relations has been moved 3 miles down the list when you right click on 2016?
Unless it's my settings that have done this?
Hi Richard,
Mine appears quite high up the list of options when I right click on a sketch;
To test if it is your settings, start SolidWorks bypassing the current settings from the RX tool, on the 'Home' tab, select 'Click here to launch SOLIDWORKS while bypassing the Tools/Options settings'. If this fixes your issue you might need to reset your registry.
Fin
Hey Richard,
Another thing you can do is map your shortcut to display and show relations. If you go to customize>keyboard and then type in relation it will show up. Then you can map it out, I have mine as ALT+R. This way now you never have to hunt for it.
Hope this helps,
Alen
When you do a right click>customize you can remove any un needed commands which may be shown now in 2016. I know it is something all of our users have to go through when we update versions. just because they will move the tools around or add more to the RMB
