I am attempting to analyse the flow through a body. I have abody, which I have created lids on and set up a flow, which seemsto work perfectly. When, however, I add another component into theinside of the initial body, I have difficulties.
I add this other component and check the geometry and interference,but get no error messages. As soon as I start a floworks analysisand try to set up boundary conditions, I am told that the face isnot on a solid/fluid layer. When I check interference and geometry,error messages now come up. I cannot work out why. Do I need tocreate a single body or something? Any help appreciated,
James
What does your internal body look like? If it has any cavities internal to it, Floworks may have refit the computational domain. If you have your computational domain hidden, you might show it and see if it is what you expect. I have had this type of problem a few times and recall it was related to the geometry of my model. On one in particular, I did a complete analysis and it worked fine. I came back to it a few days later cloned one of the projects, and then got this type of error.
Maybe you could post a picture of your model. Then we might understand the geometry better.
Cheers,
Eric
