33 Replies Latest reply on Mar 1, 2016 7:48 AM by Robert Redmond
    Macro help?
    Robert Redmond
      Anyone have any ideas on how to create a macro for Sheet Metal Thickness?
      Any help is very much appreciated.
        • Re: Macro for sheet metal thickness?
          Akshay Abitkar
          Dim swap As SldWorks.SldWorks
          Dim swFeat As SldWorks.Feature
          Set swModel = swApp.ActiveDoc
          Set swFeat = swModel.FirstFeature
          Do While Not swFeat Is Nothing
          If(swFeat.GetTypeName = swTnSheetMetal) Then
               Dim swSheetMetal  As SldWorks.SheetMetalFeatureData
                Set swSheetMetal = swFeat.GetDefinition
               Debug.Print "    Sheet metal thickness = " & swSheetMetal. Thickness * 1000# & "mm"
          Set swFeat = swFeat.GetNextFeature
          Loop
              Akshay Abitkar
              If you want to change thickness of sheetmetal features then you should add following code
              swSheetMetal.Thickness = <thickness value in double>
              For example:
              swSheetMetal.Thickness = 0.2
                  Akshay Abitkar
                  Also,
                  See below Solidworks Task scheduler process
                  1. Write a macro with hard coded input folder
                  path. This macro will open the files in a loop, update it (Change thickness) and
                  then save it.
                  2. Copy the code from the VBA editor to Notepad
                  and change the hard coded FolderPath value to $$$INFOLDER_PATH$$$
                  Const strInputFolderPath As String =
                  $$$INFOLDER_PATH$$$
                  Note: For numeric parameters use ### instead of
                  3. Save
                  the text file as a .swb file.
                  4. Open Task Scheduler (START>>All
                  Programs>>SolidWorks ‘Ver xxxx’>>SolidWorks Tools>>
                  SolidWorks Task Scheduler).
                  5.
                  Choose Run Custom Task
                    Robert Redmond
                    Hello Akshay
                    Sorry for my stupidity, im still a novice with the API, would i put in that code:
                    If (swFeat.GetTypeName = SheetMetal(Here) Then
                         Debug.Print "    Sheet metal thickness = " & swSheetMetal.Thickness * 1000# & "mm"
                    Thanks for the reply
                        Akshay Abitkar
                        Hi Robert,
                        You should set the value that you want to change for thickness property like below one.
                              swSheetMetal.Thickness = <value to update>
                               ' swSheetMetal.Thickness = 0.2
                        This will change thickness value to 0.2
                            Robert Redmond
                            Is that how it should, is it okay if it is green??
                            Thanks Akshay
                                Akshay Abitkar
                                The content following symbol ' is commented section of code. To work with it you should remove symbol ' (removing of comment).
                                See code snippet as below.
                                If (swFeat.GetTypeName = "SheetMetal") Then
                                    Robert Redmond
                                    Akshay
                                    Do i Leave : Debug.Print "    Sheet metal thickness = " & swSheetMetal.Thickness * 1000# & "mm"
                                    Or will this cause conflicts?
                                    Regards
                                    Robert
                                        Akshay Abitkar
                                        Yes, you can remove Debug.Print "    Sheet metal thickness = " & swSheetMetal.Thickness * 1000# & "mm". I have putted there for debugging purpose. As Thickness is property.  We can get/set it.
                                        Debug.Print "    Sheet metal thickness = " & swSheetMetal.Thickness * 1000# & "mm". statement will print the thicknees value. while
                                        swSheetMetal.thickness = 0.2 will change/set the thickness value to 0.2.
                                            Robert Redmond
                                            Akshay
                                            Thank you very much. By using the Folder Strings and parameters will this tell Solidworks where to look for the files i need to change?
                                            Rob
                                                Akshay Abitkar
                                                ' Change the FolderPath variable to point to the folder on your local drive
                                                ' Assumes files open are part files. Modifications will be needed to open other file types
                                                ' Add Microsoft Scripting Runtime as a reference
                                                    Dim FSObject As New FileSystemObject
                                                    Dim FileName As Object
                                                    Dim Source As Object
                                                    Dim FolderPath As String
                                                    Dim lErrors As Long
                                                    Dim lWarnings As Long
                                                    Dim bRet As Boolean
                                                    Dim options As Long
                                                    ' The folder to loop through
                                                    FolderPath = "E:\Siebel\2016\February"
                                                    Set Source = FSObject.GetFolder(FolderPath)
                                                    ' Loop through all files in the folder
                                                    For Each FileName In Source.Files
                                                        Debug.Print "Process Filename: " & FileName.Path
                                                        ' Open each file, assumes PART files
                                                        Set swModel = swApp.OpenDoc6(FileName.Path, swDocumentTypes_e.swDocPART, swOpenDocOptions_e.swOpenDocOptions_Silent, "", lErrors, lWarnings)
                                                        If swModel Is Nothing Then
                                                            Debug.Print "Model is nothing, error opening file"
                                                        If (swFeat.GetTypeName = swTnSheetMetal) Then
                                                        bRet = swSheetMetal.AccessSelections(swModel, Nothing): Debug.Assert bRet
                                                        bRet = swFeat.ModifyDefinition(swSheetMetal, swModel, Nothing): Debug.Assert bRet
                                                Loop
                                                    Next
                                                1> Open notepad , copy paste above code in it. Change the FolderPath variable to point to the folder on your local drive
                                                2>Save the text file as a .swb file.
                                                4>Open Task Scheduler (START>>AllPrograms>>SolidWorks ‘Ver xxxx’>>SolidWorks Tools>> SolidWorks Task Scheduler).
                                                5>Choose Run Custom Task
                                                6> thikness value will be change to 0.2 for sheet metal parts
                                  Robert Redmond
                                  Hello Akshay
                                  ' Add Microsoft Scripting Runtime as a reference----**** How do i do this?****
                                       Dim lErrors As Long
                                       Dim bRet As Boolean
                                       Dim options As Long
                                       FolderPath = "E:\Siebel\2016\February"--- I Have inputted $$$E:\Siebel\2016\February$$$-- Is this correct?
                                           swSheetMetal.Thickness = 2
                                  Loop
                                       Next
                                  I have done everything correctly i think but it still will not work Akshay/ anyone else who could help
                                  When i run it as a custom task, for the Parameter String i put the "Value" i want to change the sheet metal to?
                                  Regards
                                  Thank you guys
                                      Deepak Gupta
                                      Edit the macro and follow the picture below
                                          Robert Redmond
                                          Deepak
                                          When i run the Macro in Solidworks, it opens all of the parts as it should but it does not change the sheet metal thickness, do you know any reason why this is happening? When i go to run it as a custom task, it doesn't open any of the parts and just says "Timed Out"
                                          Thank you in advance
                                            • Re: Macro help?
                                              Deepak Gupta
                                              This is bug as reported under SPR #: 422119 which states SheetMetalFeatureData does not set the thickness. So as a workaround, use the codes as stated by Scott Stuart here: Re: How to change thickness of a sheet metal part via API
                                                • Re: Macro help?
                                                  Artem Taturevych
                                                  In #TASK we have implemented the another workaround (by setting the value of the display dimension of a sheet metal feature) so the thickness value can be changed on the top level feature rather than on individual bends. So the result is equal to setting the ::Thickness property (considering it works).
                                                    • Re: Macro help?
                                                      Deepak Gupta
                                                      OK.
                                                      The method suggested by Scott Stuart also works as that changes the top level thickness.
                                                        • Re: Macro help?
                                                          Robert Redmond
                                                          Deepak
                                                          Where would you insert the code from Scott?
                                                              Dim lErrors As Long
                                                              Dim bRet As Boolean
                                                              Dim options As Long
                                                              FolderPath = "C:\Siebel\2016\February"
                                                          Loop
                                                              Next
                                                          Thank you again
                                                            • Re: Macro help?
                                                              Deepak Gupta
                                                              Loop
                                                              Replace above with these lines
                                                              Dim swBaseFlange As SldWorks.BaseFlangeFeatureData
        If swFeat.GetTypeName = "SMBaseFlange" Then
        Set swBaseFlange = swFeat.GetDefinition
        swBaseFlange.AccessSelections swModel, Nothing
        swBaseFlange.Thickness = 2 / 1000 ' This would set the thickness as 2mm
        swFeat.ModifyDefinition swBaseFlange, swModel, Nothing
                                                              Loop
                                                              Also note that macro uses meter for linear values. So in case you want to change other unit like mm or inch, then divide by factor accordingly.
                                                Deepak Gupta
                                                What exactly you need to do with that macro; get or set thickness?
                                                  Viktor Bovzdarenko
                                                  Hi Robert
                                                  The macro from @Akshay Abitkar perfectly reports the thickness of sheet metal if you modify it a bit:
                                                  replace swTnSheetMetal by "SheetMetal"
                                                  see example:
                                                  but what do you want? only see the thickness or change as well?
