I'd like to define stiffness values of a spring connector in
polar coordinates with respect to an axis.
I desire the following stiffness values
K axial
K radial
K tangential
In other words, instead of having the stiffness constant in the shear plane I need to separate it into two components (radial and tangential).
See the attached picture.
Ryan
K axial
K radial
K tangential
Ryan
I know the only way. Insert cylindrical body/surface and assignthe material with the cylindrical orthotropy to it. The tediousmakeweight is that you should adjust the stiffness of thepart+material to the desired spring stiffness.
