I'm having trouble dimensioning an alternate position view in SW 2016. Typically I use this to dimension from one part in the primary view to the same part in the alternate position view to show the full range of motion. In 2016 I get an error "Could not create reference dimension from the current set of selected items." When I try to create a dimension on the alternate position view instead the dimension is created to that component in the primary view (not helpful for showing a range of motion).
Is anyone else seeing this behavior?
I'm having the exact same problem. Have a part with a telescoping tube, and I've tried dimensioning the part to itself in the alternate view, and a baseline dimension from the base to the end of the tube in both positions. When I dimension from the base, it gives me the same dimension twice.
I've attached a zip file of the part for people to play with, maybe there's just a setting that's checked/not checked somewhere?
