How to return a wire body from a macro feature
Question asked by Johannes Kronberger on Feb 22, 2016
Latest reply on Sep 27, 2016 by Brad Phelan
As a test I wish to build a wire body from a selected sketch in my macro feature.
I have the below code in my macro feature rebuild method. I select a sketch with only a single open contour in it and then build the wire body. However Solidworks always errors out and says that I need to check my geometry and/or tracking ids. Is there anything obviously wrong below?
            var cookies = SwApp.RegisterTrackingDefinition("Tracking_API");
            if (cookies == -1)
                return null; // No cookies found.
            var a = SwFeatureData.GetSelectedObjects(
                (type, mark) =>
                    (type == swSelectType_e.swSelSKETCHES && mark == (int) SelectionMarksEnum.ProjectionCurve))
                .FirstOrDefault();
            var projectionCurveSketch = GetSketch(a);
            var b = SwFeatureData.GetSelectedObjects(
                (type, mark) =>
                    (type == swSelectType_e.swSelSKETCHES && mark == (int) SelectionMarksEnum.DepthCurve))
                .FirstOrDefault();
            var depthCurveSketch = GetSketch(b);
            Debug.Assert(depthCurveSketch != null, "depthCurveSketch != null");
            var xform = depthCurveSketch.ModelToSketchXform;
            var edgesO = (object[]) depthCurveSketch.GetContourEdges(xform);
            var edges = edgesO.Select(o => (IEdge) o).ToArray();
            var curves= edges.Select(edge => (ICurve) edge.GetCurve())
                .Select(c=>(ICurve)c.Copy())
                .ToArray();
            var wireBody = modeler.CreateWireBody(curves , (int)swCreateWireBodyOptions_e.swCreateWireBodyByDefault);
            wireBody.SetTrackingID(cookies, 12);
            return wireBody;
with helper methods
        private static ISketch GetSketch(object a)
            return (ISketch)((IFeature) a)?.GetSpecificFeature2();
and
        public static IEnumerable<object> GetSelectedObjects(this IMacroFeatureData selMgr, Func<swSelectType_e, int, bool> filter)
                object objects;
                object objectTypes;
                object marks;
                object drViews;
                object componentXForms;
                selMgr.GetSelections3(out objects, out objectTypes, out marks, out drViews, out componentXForms);
                var objectsArray = (object[])objects;
                var typesArray = (swSelectType_e[])objectTypes;
                var marksArray = (int[])marks;
                var i = 0;
                foreach (var item in objectsArray)
                    if(filter(typesArray[i], marksArray[i]))
                        yield return item;
                    i++;
