Hello
I volunteer at a "maker space". We upgraded two of our computers to Solidworks 2016.
I was assigned to teach a workshop on designing plastic parts and printing them on a fff 3D printer.
I watched some number of videos on Solidworks but I never took a class because it wasn't available.
I took classes on Autodesk products before so I know what 3D cad is.
There are some questions that I have about the overall design process of this umbrella mechanism that should make a woodworking center finder that goes on a pencil.
I know that it mechanically makes no sense.
01)
First question is not even about the model. I want to create a rotor with a staggered pattern of groves/holes for a prototype I was asked to build.
Do I have to select all instances by hand to join (subtract) them from the main body?
If I increase the number of instances from 12 to something else, do I need to manually select new instances?
01 SW16 manual selection routine - YouTube
Do I really need to select them by hand or is there a smarter way to enter them into a box?
02)
03)
03 SW16 clwanup routine - YouTube
Cleanup routine.
When I make sketches, I have to clean them up by hand. Is it possible to convert all parts of circles, rectangles and other complete geometric objects into "construction" instead of deleting them, to preserve constraints and make it easier for drawings to preserve their geometric shapes?
I want to automate this process just like selecting bodies.
04)
How do I deselect a tool when I am sketching? I hit a button for line, I draw lines. Than I have to hit escape to withdraw the line command and not have lines drag after my mouse. Double click or right button don't work. What should I do?
efficiency and diselection - YouTube
Am I being efficient? Is there a faster way to draw this?
Answers to those 4 questions would allow me to design things better.
Thank you.
It may be that I wasn't able to find an answer because
a) this feature didn't change between SW15 and SW16 so new videos weren't made
b)I don't know the appropriate terminology to search YouTube for the right tutorials.
I would greatly appreciate links to relevant tutorials. Thank you.
Q3
You can select all sketches and lines holding ctrl then hit make constuction in from small pop-up window
Q4
i think double click only deselects if you move of the end point a bit other wise it deletes the line your drawing
This is on 2015 dont know if the same in 2016
