I am following a tutorial to make a speaker with surface modelling (tutorial attached)
In the beginning when i make the first loft something is going wrong. The shape i get is different from the one i should get regarding to the tutorial (see page 16).
You can also see the problem when you look to the top view i got versus the top view that is showed on page 26
Maybe someone can help me with this, i am searching for some hours but i can't find the solution.
Kind regards,
Bryan
I think i finally found it i had to drag all connectors to the other side of the loft (to the right)
And change the start constraint to Default instead of None!
